Discuss PA Testing Sheets in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Thanks Pete, I've used them and personalised them - that'll do the job. Don't do much PA testing but feel it's nice to offer it as a "foot in the door" to bigger business.
Tried it once helping my Son out at a Ladies Hairdressers, the only saving grace to the mind numbing boredom was the steady flow of crumpet coming and going.
If you're going to be doing testing, get a downloadable tester and the software will generate all your documentation, saves a lot of grief and time, this can either be sent electronically or printed and supplied. A label printer is another useful addition, saves writing out individual labels as you work.
I realise there is an additional expense in doing this however some software can be rented and it saves so much kn0bache not to mention time.
I'd probably test less than 20 items a year, and the tester I have cost a mere £100. If I had to pay more than that for a tester I'd not bother doing it.
Reply to PA Testing Sheets in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
We have been provided with an Eaton NZM-1 160A 3P MCCB in a panel for a distribution circuit on a site but was hoping to find technical data sheet...
Hi Guys, hopefully someone will know the answer. Testing an install on a (domestic) PME system I have a garage consumer unit supplied from one of...
Hello everyone, I saw in the hospital every circuit has 2 separate cpc, same size, sometimes different. I'm wondering. How we can do the dead...
For example the house today had two lighting T&E in the same MCB. I know it's fine, but as I test both 'radials' where and how do we enter them on...
Hi, Main LVAC Board, Directly Fed from a Transformer. What do i put as an OCPD on my BS7671 Test sheet? Since I don't believe the Transformer has...
