C
controlman
Have you guys come across this type of fault. A 4amp fuse on the secondary side of a transformer blew.
The secondary voltage is 24v, it feeds relays & contactors.Run with no problems for 10years. I monitored the current taken. Always around 2 to 3amps with no peaks. Is it possible for a (gG) fuse to "wear out" as it has been in 10 years. Put new same type fuse in and its running
