Discuss Panel/Convector heater? in the UK Electrical Forum area at ElectriciansForums.net
W
Welshsparky
Have a customer with no heating at all in 2 of her bedrooms ( No gas supply also ) both rooms are around 6 x 3 meters .. Any suggestions for a decent panel/convector heater that will heat these rooms adequately?
Dimplex 2kw panel heater with timer and thermostat. That's what I usually fit in bedrooms in electric houses. Flex can be short on them but so just watch what side ur spurs on.
Yep simple cheap 2KW convectors one at each end if you can. Perhaps with a separate thermostat, contactor and timer to control as i find the thermostats fitted to the heaters are a bit random and too close to the source.
Reply to Panel/Convector heater? in the UK Electrical Forum area at ElectriciansForums.net
I'm looking at a vending hot drinks machine 2.9kW that has a thermostatically controlled hot water tank permanently attached to a water supply...
I've a 3 phase storage heater currently wired to the main fuse box in an office I have. The heater has 2 supplies/isolators, 1 for charging at...
I’m running wires to the basement for future basement finishing. I’d like to add two circuits of outlets (one on the finished side and one on the...
