Discuss Panel Convert 230 - 24v in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
C
Corvus
Hi all
Just been asked about if I can make a replacment panel for a company. The old butchered panel is 240v control.
Is there any rule of thumb or so to work out what size of transformer to use to convert it down to 24vac.
I have know idea how much power contactors,relays and indicator leds take.
There will be 15 or so contactors with about 9 Led panel lights with some e/stop relays.
any ideas ?
The info is available from the control gear manufacturers website, If stocked then RS components/ Farnell data sheets are a good source too! So basically you need to know whos gear you're going to use and take it from there.
Hi all Just been asked about if I can make a replacment panel for a company. The old butchered panel is 240v control. Is there any rule of thumb or so to work out what size of transformer to use to convert it down to 24vac. I have know idea how much power contactors,relays and indicator leds take. There will be 15 or so contactors with about 9 Led panel lights with some e/stop relays. any ideas ?
can you show a pic of the old(opened up) panel?
Reply to Panel Convert 230 - 24v in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Can you provide more information about the brightness/intensity of the U 64 LED Matrix Panel from AZ-Delivery? Specifically, what is the maximum...
Hello, this is my first post here. I have a little experience with most types of household wiring through a decade of DIY remodeling, and...
Hi All, I've installed a Lorex doorbell recently, but it is not turning on. I did some tests using a multimeter and this is what I found...
We are in the process of renovating our house, and would like to setup led strip-lighting throughout. of the options, this seems most attractive...
Hello, I am fitting a Telecom 8 Compact burglar alarm system to a boat. The boat has both nominal 12v DC supply (ie up to 14.2 v when engine...
