Discuss Panel heaters in/storage heaters out in the Australia area at ElectriciansForums.net
R
rocker
Haven't had the pleasure of working with panel heaters, are they relatively easy to install?
What I'm more concerned about is removing old storage heaters, is there anything tricky involved with this or do you just disconnect and whack them out? Any help would be appreciated.
Removing storage heaters is quite straightforward but a bit time consuming. Take off the front covers and sometimes the elements need to come out to remove the bricks before you try to take them off the wall, cos if you dont and it falls on you, you wont impress your local A&E and you wont be laughing about it down at the pub either. They weigh a ton with the bricks in especially if they are the old type. Even the modern ones are very heavy so just go carefully.
Cheers..........Howard
Also beware of asbestos in some older models.
Reply to Panel heaters in/storage heaters out in the Australia area at ElectriciansForums.net
Hi Guys, Had a call out today about an odd issue with a newish Creda DT storage heater. Basically.. Storage heaters were installed in one flat...
Been round to a house to quote to replace some storage heaters for new panel heaters and came across a strange (to me at least) way of wiring the...
4K
I've a 3 phase storage heater currently wired to the main fuse box in an office I have. The heater has 2 supplies/isolators, 1 for charging at...
I get asked quite a lot about replacing old storage heaters with something more economical and I don't know what to recommend. Some people ask for...
I recently got my flat rewired. It had old storage heaters and we plan on putting modern storage heaters in. The way the electrician did the...
