Discuss Parallel circuit in the UK Electrical Forum area at ElectriciansForums.net
B
Belios69
Hi, I am training to be an electrician. I am stuck on a question and wandering if someone could help me please the question is; two heating elements of 700 ohms and 300 ohms are connected in parallel. The total resistance of this circuit would be?
Now I think I might be looking into this too much. You know when you look at something and over think I have now got to that stage.
Thanks in advance
It's a simple question so don't try to overthink it. Maybe tell us what formula you think you should be using.
As Marvo said, it's not a hard trick question, it's a simple building block of understanding and one which you should easily be able to research yourself and come back and tell us what you think you should be doing.
There's a trainee section on here for things just like this - maybe @Marvo could move it there and some mentors can help?
You must have done parallel resistor calculations at college mate it's a simple enough equation, I could give you the answer but like the others you give it a bash and we'll let you know if you are right, you can only learn if you try making mistakes is something we all do so don't be worried if you mess it up, try and get into the trainees forum you wont get any grief in there, not that youve had any so far.
Belios, there's a rule mate. No homework questions answered unless you have a go at it yourself. It has to be a proper go though mate, no daft guesses.
Same as the other lads said about the trainee bit.
I did have a go at it but just kept stumbling. I feel like a right now a couple of hours away from the books I have returned to them and seen where I went wrong. I now have the answer which is 210. And obviously 1 divided by 700 and 1 divided by 300 added together. Then 1 divided by that answer which was 0.0047 something got me 210.
Thanks for all help feel a bit daft now.
210 is the right answer, so you must have done it right. it's just reciprocals.
with resistors in parallel, you know the answer is going to be less than the smallest of them. if your answer is not, then you know you've cocked up
...And belio,fairplay to you for NOT getting impatient,going away,and having another go. This is an attitude which will greatly encourage members to assist in the future.Respect:conehead:
product over sum - the recommended way to determine the total resistance of parallel circuit with two resistor that have been different values is to use the product over sum method the formula stated as follows;
R1 x R2
_____________ =RT
R1 + R2
Reply to Parallel circuit in the UK Electrical Forum area at ElectriciansForums.net
Hello all. So I am sure the expertise on this forum will be able to decode this very easily. But it has completely baffled me. I'm in training so...
Essentially I have a "normal" socket in a ring mains, i.e. one 2.5mm T&E going in and one 2.5mm T&E going out. I am looking to simply add two more...
Hi, I had a question in my head that turned out to two and then BANG im confused. I need help with calculation here and explanation to get this...
I am a retired Electrician and started looking at Solar Power, (Black Magic to me), after much reading of "How To", I decided to build myself a...
