Discuss Parallel Feeds in the UK Electrical Forum area at ElectriciansForums.net
J
jamieb100
Doing an EICR on a building and a sub board has two 4mm twin and earths feeding it. Cables are connected into same breaker in main db but take different routes to get to sub board. Is there anything in the regs regarding as I cant find anything.
Cheers for any information or advice.
Cables should be the same size and the same length, other than that you're probably OK.
523.7
As Rockingit stated parallel sub-main feeders need to be of equal size, equal length, and be of the same construction. Ideally they should follow the same route too. There is a very good chance when they don't follow the same route/path, that they won't meet the equal length criteria of parallel supply!!
Thanks for the information, just one other question, should I put it down as an observation and what what code would I give it?
If you test the resistance of each leg of the parallel supply, you will know for sure if they are of equal length. I wouldn't mind betting that they are not!! It's your call, if your going to code it without testing though!!
I have always thought that you are not allowed to have any joints in them as well , but can not remember where i have either heard or read this !?
What would be your thoughts on this Engineer54 ?
Thanks , Dave
Joints on a dual 4mm parallel circuit, i wouldn't like to think so!! On substantial parallel supplies, i've seen joints put in direct buried cables, but normally because of damage repairs etc!! Nothing basically wrong with permanent joints in any cable, ...if carried out correctly with an appropriate joint...
Thank for your take on it !
I for the life of me can not think where i heard it so maybe i just imagined it ?
It does sort of make sense in a way , but as you say on a professionally made joint it should make no difference .
Perhaps your thinking about tap-off joints, on one of the parallel cables, to feed something else?? That's certainly not allowed!! lol!!
I have traced both cables from start to finish and there are no joints in them and the outer sheath looks in good condition. Still not sure what code to give it
With a difference of 0.05 ohms, the extra length cant be that much. I mean the difference could be down to slight movent of the croc clips when testing. Look in the OSG and do a few calcs and you will see how long each cable is. When you measure end to end on a ring, the L N results can be within 0.05 ohms and still be ok. At worst, going by what you have described, I would say C3 but as others have said its your call. Some wouldnt even code it. I may not code it if I was acctually on site looking at the whole picture.
Jay
You can work out the load sharing of the conductors, but a simple clamp meter test should suffice. Assess the load and the supplying PD and make an engineering judgement based on your findings.
Reply to Parallel Feeds in the UK Electrical Forum area at ElectriciansForums.net
Hello all, I wonder if I can get some opinion on my deliberations on an old TPN installation with numerous 1P sub-boards wired up with 16mm T&E...
Client currently has a DB in his outhouse. It feeds a pool pump and an air source heat pump. It is currently being supplied using a 4mm T&E cable...
Hi I'm installing two new sub-mains. I need to parallel some of the supply cables. It's the main incomer in 5 x 25mm, with 5 x outgoing 25mm...
Hi I've got an new outbuilding that needs power run out to it, the building is very close to the house and the original plan was to run an...
Hi. I'm being tasked with installing an electric shower into a property that was built back in the 1980's. The main consumer unit has only 4 ways...
