sparks will fly
First time post although avid reader. And first post is a question, sorry!
What are people's thoughts about paralleling fuse boards. Been asked to install a new board by linking off the existing boards supply as the current board is full. They are lug and bolt terminals so can easily double the cables up and the existing cable and supply breaker from the LV panel is big enough to protect both boards. Apart from the obvious problem of both boards going down should a fault occur on the cable, which the client understands, is there any reason why this can't be done.
*Puts tin hat on.
*Puts tin hat on.
