Jamesa2487
- Reaction score
- 3
Discuss Part name in the UK Electrical Forum area at ElectriciansForums.net
Thanks. Its from a JVC LT-50CF890 TV.It looks a bit like one of the Molex connectors, but they (at least the ones i have used) don't have an insert that is boxed like that, they are just spring contacts for one side of the pin. for example:
But maybe it is something like this:
there are literally hundreds of variations, you need to check if there is any part number on the plastic bit and/or check dimensions accurately.
Yeh I did think that after! I have got it working just a little bit of the old copper wire left in. Any idea on the clip name so I can buy one and do it properlyShould have left the plug in, cut the wires and joined them with connectors....
Thanks. I got hold of one the same but blue and brown were reversed and it was short.As above, there are hundreds of similar-but different versions, each of which is incompatible with the others and needs its own crimp tool. If you can get the OEM's cable assembly with the connector already fitted, do that and save yourself a headache.
Reply to Part name in the UK Electrical Forum area at ElectriciansForums.net
