M
martinh287
High guys had a large rewire land on my lap yesterday due to illness to another family member (electrician) first fix is already started it's possible to see all cable runs and all look ok (from part p perspective)
he has put the db board in the back hallway and has proposed a new supply to be installed at the other end of the building (bout 20m run to db board) I wouldn't have do it this way myself but the quote has been received from northern power grid for the new supply position. And to move the db board would mean stripping out 80% of the first fix cabling.
My initial idea before I go back for measurements plans etc is to run appropriately sized 3 core swa from Lucy position to db board along the floor which will then be covered by 50mm concrete and 10mm screed. Would then install 100 "s" type rcd at source regardless of supply type
The rewire would then need signing off.all year I have putting money away ready to sign up to a scam but now I'm worried this job is too risky ( may be a case of cold feet)
to base my assessment on which is why I am questioning the above mains idea and wether just to get building control in to assess for part p purposes and I just test the electrical installation and put in through my employers books.
any thoughts guys would be appreciated
