Discuss Parts for vintage service station lights.. in the Lighting Forum area at ElectriciansForums.net
Dwight
I have some vintage service station lights similar to the attached photo. However, they don't have any sockets, nor anyway to connect them to the conduit. I've been unable to locate these parts.
I made light fittings using gas pipe. A local machine shop made conduit to gas pipe adaptors for me for about £1-50 each.
Marvo did the same a few years back as I recall.
Thanks Carl. Could you elaborate more on what you did? I need something that would resemble a "NPT bell reducer". Like a 2" X 3/4". The large end would go over the top of fixture, the 3/4" rigid conduit (or black iron pipe) would go into the 3/4" end. I still would need to improvise something to hold the bulb socket...
[automerge]1574461088[/automerge]
Thanks Carl. Could you elaborate more on what you did? I need something that would resemble a "NPT bell reducer". Like a 2" X 3/4". The large end would go over the top of fixture, the 3/4" rigid conduit (or black iron pipe) would go into the 3/4" end. I still would need to improvise something to hold the bulb socket... Quote Reply Report Edit
Source URL: Parts for vintage service station lights.. - https://www.electriciansforums.net/threads/parts-for-vintage-service-station-lights.180774/
If you have the bulb socket any small town metal worker could produce what you require.
Reply to Parts for vintage service station lights.. in the Lighting Forum area at ElectriciansForums.net
Help please! Got this to use as a doorbell but unsure of specifics and wiring. If someone could maybe help with a diagram/specific parts or even...
We are in the process of restoring 4 of a group of 5 Brookhirst DC motor starters from 1936. These are a thing of beauty and the engineering in...
have a set of lights that i would like to use plug over battery. have a few plugs and old sets with cables could Frankenstein together if doable...
My kitchen has track lighting. It consists of three halogen light bulbs. I've had the fixture for more than 25 years with no issues. Last night...
