Discuss PAT testing 3 phase 5 pin extension leads in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Has anyone go any good suggestions or standard layouts to setting up two short adaptor leads to enable me to test 3 phase 5 pin extension leads, also is there any easy option without using a switch box to test the polarity of each of the Line conductors. ??
Long time Sparky, but fairly new to PAT testing.
Reply to PAT testing 3 phase 5 pin extension leads in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
Hi Hope anyone can help Can someone give me advice on how to connect up a 3 phase to 13amp adaptor lead for carrying out PAT testing on 3...
When I joined this forum a decade or so back, there was a discussion going on about a welder that was connected with a 3-core cable to L1, L2 and...
I am looking for advice on getting an upgraded 25 meter extension cable from my office into my car park to charge my EV from an IP66 rated socket...
Hi folks. Im a RECI contractor based in Co Sligo, Ireland . I was doing erroneous testing on a domestic board which gave me readings between 90V-...
