Discuss Pat testing issue in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
dj2102
If I have a Class II equipment and someone cut the plug and replaced for a new plug with earth pin. Is it will be pass or fail.
Or you have to replace for lead set ?
Doesn't matter the new plug has an earth pin. Did the old one have a plastic earth pin and why was it replaced.
Can’t see a problem with that.
Lots of class 2 stuff has a plug with earth pin, normally with 2 core flex
Is this question relating to moulded 13amp plug as fitted by manufacturer verses standard 13amp plug?
Cause if neither plug had /have an earth pin it would be a struggle to find anywhere to plug it in.
Yes it was moulded plug but someone cut and put the new 13 A plug with earth pin
For me if is the II class equipment and someone had a fault on the moulded plug. What should do replace the for new moulded plug with a cord like was before.
Because this will be comply with a definition of II class equipment
The appliance is Class II and manufacturers produce moulded plugs with plastic pins as it costs less and is only required so it can be plugged into a socket.
Look up the definition of class II equipment in the ISITEE code of practice. It does not preclude the use of a plug with a metal earth pin for class II equipment.
You've obviously made up your mind already, so not sure why you asked the question in the first place.
Reply to Pat testing issue in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
Performing the PAT inspection on some science equipment and I have found some items that were passed by the previous company that performed it...
Hi, I carry out PAT testing on landlord appliances for letting agents in rented accommodation. Occasionally some of the items I cannot access...
Hi all, Not sure if asking about rates is allowed, but I'm wondering what people's thoughts are on chargeable rates for PAT testing. Baring in...
I am a new PAT tester for a school, and I am stuck testing a plasma globe. It has a two core wire going to it, but no class 2 mark on the...
