Discuss PAT testing transformer plugtops in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
spud1
When PAT testing is it necessary to carry out insulation resistance or load/leakage on a Class II (Dummy earth pin) transformer PSU type plugtop? (e.g. phone charger, monitor PSU) Or is just a visual inspection needed?
visual only. IR testing L-N would be pointless and could fry the PSU.
No PATester carries out a live to neutral test (should be linked within the tester). The IR test should be carried out to the metal parts of the outgoing plug using the earth bond lead but always check the testers instructions.
Yes, it is a fundamental safety aspect of the transformer / electronic power supply that it provides adequate insulation between the 230V input and the ELV / Class III device it powers. Therefore an insulation or leakage test to the ELV output is important. Some non-compliant / fake / firecracker phone chargers and their like have deficient insulation that is a smoke paper away from causing a serious shock or electrocution when someone touches the attached phone.
might that not fry the device, though?
very rarely do pat, so i bow to your judgement. problem is, these units usually have a funny socket on the elv side and you can't get a connection with the desparate dan crocs on your MFT.
Reply to PAT testing transformer plugtops in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Hi, I carry out PAT testing on landlord appliances for letting agents in rented accommodation. Occasionally some of the items I cannot access...
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
Hello, I am currently learning and have come across PAT testing an old chandelier. On modern lamps I would use the plug and probe on the...
Hi Hope anyone can help Can someone give me advice on how to connect up a 3 phase to 13amp adaptor lead for carrying out PAT testing on 3...
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
