ElectricN00b
- Reaction score
- 0
Hello experts,
I have a question about an external molex power supply. It's a 34W rated power supply commonly found on ebay. The pinout is:
12v @ 2a | not connected | ground | 5v @ 2a
Can anyone please give me the possible reason for the non-connection of pin 2? Normally that pin is a ground. This is a problem because some disk drives will only work if both grounds are connected. I can get them to work by connecting the two ground pins together. But, I am concerned by unexpected moments when things could start smoking.
The cable between the the power brick and the molex connector is: "AWM E138922 STYLE 2464 80C (celcius) 300V VM-1SC CSA LL81295 | A/B 80C 300V FT1". Is the single ground wire in this cable capable of handling the load if both the 12v and 5v lines are at maximum output? Since the power supply is a cheapo unit, there may be plus or minus deviations on both the voltage and amperage. What is the likely maximum watts the single ground wire can handle?
Thanks.
Thanks.
