Discuss Periodic code in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
J
jimmer
What periodic code should be put down for circuits in a domestic house not on a rcd i.e. immersion, lights on old split load boards.
Any help much appreciated
There are some interesting recommendations in this guide, for example a 'code 4' should be issued for:
'circuit protective conductors of final circuit protective conductors in a consumer unit not arranged or marked so they can be indentified for inspection, testing or alteration of the installation'
I think a 'code 4' probably applies to most installations in the UK.....lol :D
Reply to Periodic code in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Another thread asked about two circuits sharing a common multi-core cable and regulation 521.8.1 was mentioned. A friend of mine has inherited...
Hi guys. I had an inspection yesterday, where the lighting and sockets are in one circuit for each floor. There are 3A fused spurs for the...
Did a couple of inspections on 2 x 2 bed ground floor flood damaged flats today, only 4 circuits in each, bizarrely one socket circuit and 2...
Hi I am carrying out an EICR. I have a garage mini sub DB supplied via 2 x 2.5mm T&E equivalent 5.0mm protected at main DB by a 32A mcb. I know...
