Hi folks - new to the forums here. Forgive me if this isn't the right place to post. We have a small home, just moved in and noticing that 24 hours a day, once about every minute, ALL the lights in the house flicker at a pretty fast rate for about 10-15 seconds. It repeats this cycle 24 hours a day. I have tried to notice if any appliances might be causing this, but I don't believe is the case. There is not a ton of things in the house. Fridge not running, microwave off, gas range off, I don't believe direct in-line water heater causing it, and gas furnace for heat off, washer and dryer off. Everything off or at least not running except for a few various lights.
I'm wondering if any advice before I call an electrician to help investigate. How does one know if this is an issue with the service to the house vs something within the house causing it?
Thanks so much -
Brad in MA
Thanks so much -
Brad in MA
