Hi
Im a scottish spark. Only been put my time over a year so need so guidance. When doing i periodic the cu is old mcbs so there is np rcd protection. No sockets are likely to be used for lawn mowers etc and none in the bathroom so i would label as code four. Same with bonding in 6mm less than 0.05 so code 4. ElectrIcal install fine. Tested good. Passed visual.
Guy wnats a landlords cert for renting obv you would advise on cu upgrade to 17th bit if it doesnt want it due to cost. Is thos a big issue
Just looking for some guidance on this
