Discuss PFCs in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
stidge
hi all
Firstly could someone tell me BS number for rewireable fuses
Also has anyone got a list i could have of all the breaking capacitys of all fuses
Much appreciated thanks:eek:
bs 3036 re-wirable fuse. not got the list to hand sorry mate.
Hey.
BS 3036.
I'll see if I can find a table.
Cheers
Hi lenny could you please read my thread (protective bonding in an indoor horse arena) its been posted a few days but had no feed back and could do with the advice thanks. :)
Reply to PFCs in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I've recently has an EICR (report attached) carried out on my two bed flat because I need to rent it out for a year. The electrician has come back...
Hi all Please can anyone tell me the type and breaking capacity of a 60amp bs5419 isolator fuse like you'd find in a sub main for a flat. thank...
I have been asked to change cu from old fuse board which has 6 fuses. Only 4 fuses are used. The first fuse feeds cooker circuit. This is not used...
Hi I have a switched fuse spur where the cooker hood should plug in to… above the actual cooker. I was wondering if I could swap this out for a...
Evening all, I'm relatively new to the trade and have just moved house. Looking to rewire and was looking at a few things, could someone tell me...
