Discuss Phase-phase fault in the Industrial Electricians' Talk area at ElectriciansForums.net
M
matyii
To protect equipment eg motors, generators, against phase-phase fault, one uses a Negative Phase Sequence Relay. Appreciate if anyone can explain the working principle of the relay. Is it similar to normal over-current IDMT relay?
Whenever there is an imbalance in a circuit, the imbalanced currents will have a negative phase sequence component. A negative phase sequence (or phase imbalance) relay is often provided for the protection of generators and motors against imbalanced loading that may arise due to line-to-line faults. Such a relay has a filter circuit, which is responsive only to the negative sequence components. Since small magnitude over-current can cause dangerous conditions, it becomes necessary to have low settings on such relays. An earth relay can also provide the desired protection but only in cases when there is a fault between any line and earth. For line-to-line faults an earth relay cannot provide necessary protection and hence a negative phase sequence relay is required.
Reply to Phase-phase fault in the Industrial Electricians' Talk area at ElectriciansForums.net
Good evening! Don’t have a huge deal of experience with fire alarms but having to work on a conventional system at the minute with various...
Good morning, So I’m working on an existing 3 phase solar system and the customer wants a way to use the huge mass of exported solar on their...
I posted a month ago regarding a single phase motor + panel I have been given to try and sort following water damage to the panel. The assembly...
Hi all I am new to this forum and hope this is right placed and of interest. I would like to make a setup with one or more impulse relays...
