Discuss Phillips or Pozi in the Electrical Tools and Products area at ElectriciansForums.net
I can only imagine its because the mass of screws produced means they wre chepa to buy. I don't know any electrician here that uses them much, mainly square head used here.
I use loads of screws.
Cable cleats, distribution boards, back boxes, trunking, lights.
They all need attaching to something
Blue tack is great for posters in the kids rooms but I don’t think I would hang a light fitting with it.
I presumed he meant he doesn't know why they still produce that type of screw, not why they still produce screws all together. I also use screws, some would say I am a fan of the marvellous piece of material that they are.
Not so much that I didn't know why they're still produced, but why they remain so popular. I use square heads for almost everything and could count on one hand the number of times I've damaged one - those few occasions were driving at a severe angle with an impact driver. Compare that to the number of times anyone who owns a screwdriver will have encountered a damaged Phillips or Pozi head...
Phillips and Pozi serve a purpose, but have significant limitations and more reliable alternatives have existed for as long as those two screw forms have been around. PH & PZ are a better option than slotted drive, but not significantly so.
I think pozi are better than slotted by miles, especially if using a Yankee driver!
[automerge]1597788609[/automerge]
Also, if you use proper pozis, like turbo ultra, they self-drill and drive very quickly...but those chinese ones made of case-hardened cheese are a disaster...pit an impact driver near them and they melt
I agree. I keep a small selection of pozidrives in large or random sizes that square heads aren't available in. Slotted drive i never use. Only slotted screws i use are for screwing up faceplates.
My father seems to have a never ending supply of slotted screws in every imaginable size, although he invariably uses an unsuitable size for every job (most likely whatever was in his pocket at the time). I hate the things with a passion and my heart sinks every time I see a slotted screw with its slot partially sheared.
I have some slotted screws in big sizes, left over from my boatbuilding days. They are silicon-bronze and pretty massive. used to drive them in with a brace and bit...museum pieces now, I guess. i do remember they were incredibly expensive, but were preferred to stainless steel, particularly underwater, for their corrosion resistance. As mentioned earlier on another thread, one of my boats had a lot of Robertson screws...nice finish, but you need the right driver...
[automerge]1597791741[/automerge]
Is it just me, or do you all like fastenings? I marvel at the huge rust-proof coachscrews i used for decking jobs...bung a socket on your SDS and just drive them home...and those Multi-Montis and suchlike for concrete etc...pilot hole, drive them in, use a socket or whatever...solid! And today's wood screws, of reputable makes, they just do the job for you...no pilot, just drive...how did we ever manage without them? Well, we did, but it's just so much easier now. Only downside i see is the finer shafts, but actually haven't found many problems with strength.
Also fine in faceplates and many other applications, but don't belong in places where significant torque would be required to tighten them. Aesthetics is one all well and good, but not to the detriment of practicality.
I prefer people to ask for a 'crosshead' screwdriver, so that I have an intro for asking whether they want Pozi and Phillips so that I can give them the right one. If they come asking for one or the other, it's a bit presumptious to suggest they might be wrong and grill them over what kind of recess their screw has. I usually say something like 'Please only use it for Phillips screws, if you need a Pozidriv too, you're welcome to take that as well.'
'Actually, I think you need a JIS' usually draws odd looks. I keep and use them regularly as I often work on Japanese equipment.
Much prefer if tradesmen came to work with the range of tools they might need during the course of their day.
I know this isn't an ideal world, but what sort of plumber goes to work without a selection of commonly used screwdrivers?
I'm sure they do, the universal set Telectrix has posted :rolleyes: I think it would be fairer to say that most have zero idea that there is more than one type of "cross head" screwdriver - and just have one crosshead driver - and well worn so it can chew up even matching screws.
My heart used to sink on site, when Mr Plumber came along to borrow a "cross head" screwdriver. The question as to if he needed a Pozi or Philips always seemed a difficult one.
I carry two PZ2, the (new) good one and when its due replacing its downgraded in status to the "loaner"/undo old graunched screws/use on mk&wylex and other combo-fit-nothing-properly-heads etc.
never understood the point of pz, always found less slippage with phillips. pz seems almost made to degrade
I find quite the reverse - Philips is very bad for camming out so you can have to push quite hard to avoid cam-out while shifting a stuck screw, while Pozi is generally much better.
BTW - I 100% recommend the Wera "diamond" bits, they really do make a difference.
What phillips are we talking - the ones typically supplied with light fittings - always cheap rubbish, and rarely attempt try to use 'em, reckon theyre phillips size 1 ¾ , must be a chinese thing!
the black ones used to fix plasterboard the screwdriver seems to go really far deep down inside and never slips!
PS have we had the decorators favourite yet, 2 fixing screws, one (preferably half shank) slotted and one crosshead! hedge the risk!
Reply to Phillips or Pozi in the Electrical Tools and Products area at ElectriciansForums.net
Hi Forum, I had drain cameras plumbing equipment and tools, I was just wondering how much voltage the right drain cameras would have if we...
I was working alongside the plumber yesterday. I had to drill some 32mm holes through joists. I always use my Makita 481 high torque drill will a...
CityElectricalSupply.com (CES) are an electrical supplier across the United States with over 550 branches coast to coast. Here in the UK we...
I see they're introducing a new type of flat twin cable with a sheathed CPC. In my location there's no requirement to sleeve CPC/bonding...
A friend of the family recently lost her husband to the big C so I need to be careful. Every small thing is sending her into tears so when her...
