Discuss Photoelectric Cell Sensor Light Switch in the UK Electrical Forum area at ElectriciansForums.net
Deleted member 105166
I'm looking for a photoelectric cell solution for two way light switching at the top of a ground floor staircase that descends to a basement. As the staircase enclosure is a feature in itself (open, oak bird cage effect) there is no option to attach a conventional switch anywhere.
We've wired for a device in the wall just above the second step from the top, so the beam will open when you begin to go down to the basement.
I've found these, which I'm familiar with as they're similar to what we've used on the roller shutter in one of the outbuildings, however they are too large and obtrusive for indoor domestic use.
Can anyone recommend a small, discrete device that will achieve the same result? Ideally the TX will be small enough to recess and make good, with a small reflector opposite.
mask off the side that you don't want to activate.
Reply to Photoelectric Cell Sensor Light Switch in the UK Electrical Forum area at ElectriciansForums.net
Hi All, I am rewiring my basement, which includes the stairwell that leads from the main floor kitchen down to the basement. Here is an idea of...
This isn't really an electrical issue as such but I know you guys are pretty tech savvy and familiar with all the latest and greatest...
so i have been given this diagram and no explanation on what nay of it does, its for a safety relay for a robot cell it says this: 'Safety relays...
4K
Hi all. I'm currently renovating a house and have one particular requirement I'd like, if possible, sme suggestions. One of the things I would...
Squid
M
Anyone got any thoughts on this? I've got a job to do installing an additional fluorescent (to provide localised light for a work area) in the...
Mega Greg
M
