Discuss Pics of Sonos wall mount setups in the Home Media Centre Forum area at ElectriciansForums.net
E
ecochap
Hi all,
After some guidance with a Sonos setup. Looked for a few decent multi room media setups for our home and the Sonos products look right up my street. My question really is how have people run the supplies to the units. I want to give the impression that the units are completely wireless and not to have bundles of power cords strapped down the wall to the nearest socket. I want the speakers mounted high level out of harms way ideally.
Currently have some of the upstairs floorboards removed to gain access. Would you fit an FCU unit at each individual speaker? (2 in each corner of the rooms) and then hardwire the power cord. This seems the best method in terms of maintenance and dissemble ect but a bit of an eyesore having an FCU 2 meters up the wall (I say 2 meters as itl be a pita to try and run a feed through the stud wall from any low level sockets.). My other thought is to get some flex through(or the sonos power cord) at the speaker locations and make a joint at each location in the floor all being supplied by one FCU near the soundbar (fused to the rating of the equipment or 2 FCU's if we go OTT with speakers and equipment. )
The other question is the Ethernet connection. Do you guys tend to hardwire or leave it wireless. We only have a 3 bed semi so the wireless should be pretty reliable but I'm keen for hardwiring where poss.
Any pics of your previous installations would be much appreciated. As you can see im a noob when it comes to home cinema/multi room systems but I'm trying [emoji2]
Thanks. Joe
When I've installed the Sonos and the clients want the speaker high up I would use the Sonos Amp and separate speakers. What units are you installing?
As for the ethernet connection I would run it to the amp or use a Sonos Bridge the mesh network that the units use is pretty good so normally don't have to run ethernet cables to every device.
Reply to Pics of Sonos wall mount setups in the Home Media Centre Forum area at ElectriciansForums.net
Hello, I have installed 6 recessed lights in my living room as well as wall boxes. I’m now at a point where to need to run the wiring. I plan to...
Disclaimer: Not a pro sparky, so i have no intention of doing this myself, but I am looking for options that I can then take to someone qualified...
6K
All of the UFH thermostats that I have ever fitted have had the air temperature sensor integrated into the hard-wired wall mounted programmer...
  • Locked
5K
Hello Need guidance powering / charging a RING Pro video doorbell. Have an old home intercom system M&S MC602 (its powered by TE-5B...
4K
