Discuss PIR CU Change and EIC in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
W
WarrenG
Interested to know if others take this route?.
If a customer wants a CU Change and have not got any previous electrical records do you PIR first to check the installation and also pick up any remedial.
Then complete the CU Change.
Then supply an EIC.
Comments Appreciated :)
thats what i would do, my mate got stung a few years back, got a phone call of a woman he never met went round changed her consumer unit witout testing it first, when he came round to testing the new one sooooo many faults it was untrue.
the woman says well it was allright before!
haha he has never done it again
For my own peace of mind, i tend to IR test circuits first and check for borrowed neutrals.
Once thats proved ok, then on with the cu change.
I do all the dead testing plus zs to make sure the maximum disconnection times for rcds will be easily met. Of course charge the customer for this 1st test and explain why. It might knock a few customers back from using your services, but it prevents you from potential headaches afterwards.
Hi mate
I would generally test before swapping the board and not charge them for the EIC
After fitting £70 pir, charge for remedials £250 board and just issue the EIC
Hope this helps :cool:
Hi mate
Thanks all for the replies!
you should always aim to keep cost down for the customer so when you do an estimate check what wiring there is estimate the age look for visual alterations then you should be able to estimate what problems can occur put all this in writing in your estimate and state any fault finding rectification will be carried out on a time and materials basis after all if there are faults they need rectifying so do the change then test then do another estimate for cost of repairs as faults are allways found when testing espicaially with all the new regs .
Reply to PIR CU Change and EIC in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
So I am a fully qualified spark with my own company, however I also have a few properties I rent out. One of my tenants asked if they can have an...
10K
Morning All I recently completed my first re wire and board change, (with help from the owner who is a gas fitter and plumper, who works with my...
I really hope someone can help me. Last July I got an electricity bill showing an enormous rise in my kwh consumption of about 900% from what it...
Hi All, Not sure if this is the best place to post but here goes! I'm over 50 and not working at the moment (semi retired) but I'd like to get...
Hi folks, first time poster and soon-to-be landlord's assistant (letting my partner's property out now that she's moved in). We've just had a new...
8K
