Discuss PIR Floodlight - how bright does it need to be in the Lighting Forum area at ElectriciansForums.net
Hello,
I want to install a PIR Flood light which overlooks my car and drive.
i have looked at different kinds of LED lights but i'm wondering what power i need?
I don't want a light that is just going to light the area up if someone goes near it... i want it to make it hard for them to see and actually be a security deterrent rather than just a light.
Any help would be greatly appreciated.
Dan
In all the one piece security lighting I've installed recently, the product has been let down by its PIR sensor, and being able to direct the sensor effectively.
If I was doing it, I would want a separate luminaire & good quality sensor. So the light could directed in one axis etc, and the sensor in another.
The larger size for domestic use is 50W. An Ansell Carina 50W (for example) will give about 3700 lumens for a bit over £30. I'm not sure if it's quite the military grade needed, so perhaps you need one of these ... about 10 times more and focussed into 30 degree beam angle. I've not used one, just found it out of interest :) .
My drive is recessed down the side of the house with fences on the left so it wouldn't light up their side I don't think. We'll he is a bit of a pain anyway but he has about 20 small solar panel ones but they are crap... Almost illuminating the way for burgulars if they wanted to walk up his drive. I think I might get one of those steinel sensors and fit it to the light . If the light is too bright it can always go back to amazon as they will accept any return for any reason. Thank you all for your help!
Reply to PIR Floodlight - how bright does it need to be in the Lighting Forum area at ElectriciansForums.net
I've just changed the bulb in an outdoor PIR security floodlight (to LED). But the light stays on by default, and turns off when I go outside. I...
Electrical2Go - Home Security: Using Floodlights, CCTV, and Door Entry Systems In an era where technology is advancing rapidly, home security has...
Hi. I'm an I.T.. engineer with some outdated electrical experience. I qualified C&G 2330 17th edition about 15 years ago, but my only experience...
Driven by the recent colossal hikes in the cost of electricity I hit upon the wizard wheeze of replacing some of the existing LED bulbs in our own...
