Discuss PIR from hell in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
S
spark-doctor
This is quite easly the worst place i have seen in 15 years. I have only scratched the surface and am still doing the visual inspection part, have only done a couple of tests on circuits i found with visual faults. Am going to be there for about another 3 days. It is a hotel in Dorset, with new tenants. Just moved in and have discovered that hardley anything works properly.
thats looking good, to be honest as a new spark I wouldn't know where to start :S but let us know how you get on in the next few days, you working all weekend ?
thanks for uploading the photos!!!!! keep em coming
Yep, got to work all weekend. Where i am, nobody wants you in during the week except for breakdowns and we are in the busy period but weekends are usaly the changeover period.
I am dreading what else i am going to find in this place.:mad:
From hell...or heaven?
Judging from the photos they can´t really complain about the amount of code 1´s and 2´s you put down.
3 days work? So you´ll get 600-900 quid out of it and if they don´t want the remedial work carried out then you´ve still had a reasonable earner - on the other hand, if they do, then there´s more work for you.
It is getting worse. I finished the visual check today and started on the testing. Amazed that no one has been hurt in this place.
1) No earth bonding ANYWHERE except to the gas pipe and that was 3m from the meter and a new clamp on a painted pipe.
2) Not one RCD in the place.
3) They have exported PME to a shed with 8 large chest freezers, 40m away with 2.5 SWA. Did not bury cable, just layed it in the flower bed.
4) One CU was just sat ontop of another as they could not fix it because of the amount and postion of the cables coming out of the back.
The list goes on and on. I have run out of space in the observations box on the form. Is looking more and more like a rewire.
Will post some more pictures when i have had my dinner and done some paperwork.
My mistake....I did wire this one :)
quote]
NO earth bonding?
NO EARTH BONDING:eek:
you gonna put that on the report are you?
If you gave that to me i would laugh, rip it up and send you on your way
mate should you be doing PIR's?
Presumably you have 2391? How did you get it if you dont know the basic terminology?
Now then, back of the class, hands on your head, and face the wall:p
Whilst I appreciate that on any form of report the terminology has to be correct I am sure that there are not many of us within the forum who have not done work involving 13amp sockets on a "ring main" or even replaced a "bulb". (Bulbs ar things you put in the ****ing garden, as my old tutor used to shout at the class!!) :(:eek: Infact look at the title of the icon in the post icons section below the reply space.:rolleyes:
Back to the subject of the thread, this is a beauty, it makes you wonder what the person who installed it thought he was doing. The thing is if you now update it and fit rcds etc it will start to trip out owing to appliances and you will be confronted with that wonderful phrase, "we never had any problems like this until you started working on it".
If you get the remedials good luck, it should keep you busy for quite a while.
Fair play theres some beauties there. I would imagine you'll discover some more horrors when you test.
Got something similar coming up in an old farm building with stables. Electrical work over the years has just been added to and no one has really taken responsibility for work at the distribution board which is hanging off the wall with more holes in it than Swiss cheese. No RCD in place either with two electric showers and sockets in outhouses and stables all over.
Might have to look at changing that.
we changed a consumer unit (an old fuse board) in one of our units the other week, been there for donkeys it had
there was a ring fnal, and a radial going out to a FCU for a boiler.
when we tested it, one leg of the ring was in the fuse supplying the radial, and the radial was joined with the other leg of the ring in the 30A fuse:eek:
and yes, it HAD PIR's 'done' on it and signed off......freekin' cowboys
quote]
NO earth bonding?
A pedant, or pædant, is a person who is overly concerned with formalism and precision, or who makes a show of learning. The corresponding (obsolete) female noun is pedantess. Someone overly concerned with minutiae and whose tone is perceived as condescending.
i know what he means, you know what he means.
with no main earth or main equipotential bonding,you should leave the testing well alone, jank the install, write a quote and start again, also guarantee your work for 12 months.
Reply to PIR from hell in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hello everyone. Budding DIY enthusiast fascinated with how things work - and, to a lesser degree, fixing things that are not working. I suppose my...
So a quick catch up so you can get an idea… I was asked to do a job for another electrician, as he is too busy. I’m busy myself but said I’d...
Well....wiring in a 1750s thatched cottage attic, not wiring made from thatch 🤪 One we have been letting for over 20 years (as well as enjoying...
4K
Hello everyone, I hope nobody minds that my first post is a question. We have a bit of a situation brewing at home with regards to our new...
4K
