Discuss Pir - spot the fail competition in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
You took the cover off before isolating the CU!!!:eek::eek::eek:
That RCD doesnt look right to me.
Other than that, i though i did quite a nice job of that install.
Err.....,
Taped up conductors, mixed make of MCB's, untidy, no 2 colour labels, missing BB shroud, no blanks.................
i give up.
It is a friday night ya know:D
edit: No main earth??
& i`m struggling to see the neutral outgoing from main switch actually making it as far as the neutral bar
Please tell me my eyes are shot...
lol i actually deleted it as i thought i was too late
oh look its back, is there a screw on the neutral terminal?
Reply to Pir - spot the fail competition in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi all. I recently failed a section of my AM2E assessment. Passed 7/10 but failed on some silly things I'm confident of correcting second time...
Confused as to what the earth fault loop is. I'm aware it's the path that fault current takes (Line-Earth) but how many times does fault current...
I have carried out home wiring for 60 years as a competent person, for the last 20 years, I employ a local electrician to check my work and sign...
Hi not sure if this has been covered before or not but here goes, Qualified Electrician currently wiring my own garage. I have 6 spot lights, 2...
I am installing a Victron Quattro in an island mode configuration (in the UK, the DNO is the NG). I will be adding a stand-by generator. My...
