A client of mine has asked me if it is acceptable to build planters over the lighting earth rods around his building. I told him that as I have never installed nor tested/inspected a lightning system he should seek guidance elsewhere. However common sense says that if there is a facility to inspect the rods it is probably required. He said he wouldn't mind if they had to be dug up once in a while but every year would be a problem. I had a look in the BS and it says where accessible rods should be inspected for corrosion. The words 'where accessible' make me think it might be acceptable to bury them? I guess what I am asking is - When tested/inspected are the rods always visually inspected or are they only inspected if a high reading is measured at the test point? Thanks for your input in advance.
