Discuss Please help me identify this switch in the Australia area at ElectriciansForums.net
M
MikeyG
Hi,
I'm hoping someone might be able to identify this switch and where I might be able to source one.
It's located outside a bathroom and operates the bathroom light and extractor fan. Left to right: light switch, fan switch, fuse (presumably for fan). As you can see the faceplate is damaged and I'd like to carry out a straight swap - if I can get hold of one.
Thanks All.
By safely removing the face plate you might find a manufacturers stamp etc on the reverse or on the frame that holds the switches. Only thing is there are similar looking face plates from most manufacturers and some from illegal imports.
Best of luck in your quest.
Deffo Delta MEM supergrid if i remember correctly , still available, should be able to pick up a replacement front grid plate. Otherwise may have to change the whole thing for a new grid switch .
Nick
Thanks for the swift responses guys - good advice, I'll pop round to my friend's house and take a look at the back of the faceplate.
Reply to Please help me identify this switch in the Australia area at ElectriciansForums.net
Hi all, Got an awkward bathroom fan installation in a downstairs flat, concrete ceilings and (some) walls. Bathroom is already fully tiled and...
My extractor fan has given up the ghost this week and I was hoping to replace it myself, however I cannot do a like for like swap as the current...
Hi I have a job where customer has two families one families lives upstairs and one family will live downstairs. As the property is going through...
