Discuss Please please help me. in the Electrical Forum area at ElectriciansForums.net
I would like this 3 way switch wired up but have no idea how I took off a 2 way switch and fitted a 3 way switch in its place I have ran a new cable for the two down lights I'm trying to power. The other two old cables are powering a downstairs light and a top of the stairs light.
  • Please please help me. IMG_20200411_081958 - EletriciansForums.net
  • Please please help me. IMG_20200411_081924 - EletriciansForums.net
  • Please please help me. IMG_20200411_081849 - EletriciansForums.net
Hi, it's not totally clear but it looks like you have 2 3-core cables in old colors there, have u reinstated them exactly how they were in the old switch? I assume the little link cable in brown is a new addition, and the brown & blue 2 core cable is the feed to the new lights?
If so, it's not going to work unfortunately has you have no neutral there to take to your new downlights,
If so, it's not going to work unfortunately has you have no neutral there to take to tour new downlights,
Correct two old colours same as before new cable has a blue and brown and earth I have earthed to backplate I just don't know how to make it work ie where to put the blue and brown and the little brown bridge cable please help
Where are you getting the neutral for your new down lights from?
There are a couple of issues here with regard to the wiring of the light, the blue & brown shouldn't be visible outside of the fitting, the 'earth' wire should have some yellow and green sleeving on, and those downlights don't look fire rated so are likely to be unsuitable.
However I think the main issue as post 2 is that you don't seem to have a neutral at that switch already so you can't connect your new lights in there.
If the existing lights are 2 way switched, the neutral may be at the other switch, or more likely its at the light fitting its self, or a junction box in the floorspace or ceiling. Are you fitting these in a ground or 1st floor ceiling?
It also looks like there's no other earth's (cpc's) at your switch so although you've done the right thing with your new cable, your downlights won't be earthed.
Ok advice on the cables taken here is an image of where the lights are going it's in a canopy outside my front door
[automerge]1586592757[/automerge]
The main thing I'm asking here now is how can I get these lights to work lol
  • Please please help me. IMG_20200411_091002 - EletriciansForums.net
Post #2 mentioned about not appearing to have a Neutral at the switch. If that is the case, they you need to rewire them from somewhere that does have a neutral.
I suggest you wait till you can get an electrician in.
So on the old cable in there is the red yellow and blue none of them are neutral?? I'm guessing live switch live and com ??
[automerge]1586593155[/automerge]
  • Please please help me. IMG_20200411_091905 - EletriciansForums.net
Probably not. You should not assume just because a cable is blue (or black) that it is a neutral. At a switch, it was not common to bring the neutral to the switch, at least in older properties.
I think your best bet, as per SJD, is to wait until you can get an electrician out. They may well be able to use their skills and experience to sort out the issue, there's a way around most things!
As with the above, it is quite common for multi-gang 2-way switches to have been cabled in whichever way was most convenient for the installer, sometimes resulting in duplication of functions of some of the cable cores. If you are lucky, the existing functions can be reconfigured to free up one conductor in an existing cable to serve as a neutral. However, if the existing lighting circuit has no CPCs, the wisdom of connecting anything new to it, and not taking the opportunity to rewire and upgrade it while working on it, is doubtful.
TBH I don't think it is practical to advise on this effectively, not least because there are so many possible configurations, plus there is the issue of the lack of CPCs for your new fittings. I don't often say this but it does look like a job for an experienced electrician.
I have to agree with Lucian here, simply not worth the risk.
If you do want to do something to help you could try and see where the junction box(es) for the existing lights might be located, but until the installation is understood by whoever will fix it then I would leave out any testing.
Reply to Please please help me. in the Electrical Forum area at ElectriciansForums.net
