Discuss Plug and play hot tub tripping the rcd. My cleverspa trips the rcd plug as soon as i plug it in. in the UK Electrical Forum area at ElectriciansForums.net
Darrin
I have a clever spa portable spa and as soon as i plug it in the rcd plug trips. What rcd plug can i get to replace it. Is it the rcd plug thst is faulty?
Not sure exactly what is tripping, sounds like an RCD unit that plugs into a socket?
In which case, the RCD plug-in unit could be faulty, or the spa itself could be faulty, or the socket that you are plugging the RCD into could be faulty. Without any testing, it is just a wild guess.
Its a rcd on the end of the power cord from the spa. I have replaced it with a 30 ma one but that trips too. The original rcd is 10 ma , would the 30 not work? I suspect a faulty rcd as the spa is only 2 months old. Do you know if these inflatable tubs have specic type rcd,s?
You've ruled out the RCD by swapping it out, but not interpreted the result of your testing. The other elimination test is to plug a different device into the same point with the RCD back in. If not tripping immediately, it will be the hot tub
There is a fault on the spa and it should not be used until it has been repaired.
The RCD is a safety device doing its job and swapping it for one with a different rating is against the manufacturers design and potentially unsafe.
Reply to Plug and play hot tub tripping the rcd. My cleverspa trips the rcd plug as soon as i plug it in. in the UK Electrical Forum area at ElectriciansForums.net
An RCD keeps tripping. Please see attached photo of the board (2 photos attached). I’ll call the breakers: MCB (1) marked ‘Upstairs lighting’...
Hi all, we had our gas hob removed months ago and finally just got round to putting an induction hob in. Its a normal 4 ring induction but one of...
Hi all, Been a while since I have been on here. I have been on an apprenticeship the last 3 years training in the BMS world. Taking that into...
I have just checked a double outlet and it trips at 18ma. It was supposed to be faulty. Washing machine had a bad heater which got replaced but...
Hi, I seem to have an RCD that keeps cutting the power at random times without actually tripping, if I reset it, the power comes on and will stay...
