Discuss PME and Earth Rods in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
R
rasell
Is It OK to have both?
Some people seem to say it can create a dangerous PD, but is that right? If you have earth bonding thats not that different to an earth rod, as the pipes go through the earth.
I think I read somewhere in the regs or somewhere that an earth rod can be considered as a backup in the case of a PEN fault, otherwise all earthing could become live and you could even get feedback from other properties!
Regards
Marc
I am strong believer that there should only be one earthing point.
If you have PME, the supplier has taken responsiblity for the provision of a satisfactory earth point. Almost every joint of an underground cable has an earthing tail, and every second post has a PME spike.
It was explained to me by an inspector for the HV boys, if you used a earth rod and PME, you are in fact providing another earthing point for the whole grid.
Not that it happens every day, but if the pole outside gets hits by lighting, that energy may decide to earth via your house.
Perhaps an earth rod with a surge protector built in :D
Marc
Reply to PME and Earth Rods in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
5 single phases to one huge property. Backup generator which can take about 106 amps split between 2 phases - 1 phase will be wired through...
Hello All I was pondering an idea recently regarding the ground connection to my property. At present it has a combined Neutral to earth at the...
Hi Currently on a job at a hospital where we are installing temporary site supplies to canteen toilet block and office. The supply is Tncs from...
Disclaimer: I'm not going to attempt this job myself, I want a professional to do this job properly since I consider it non-trivial and need it...
After conducting a recent EICR I found among other things that the Galvanised columns in the carpark area of this premises seem to be connected...
