deegee
I have a query,
Im working on some signage that is connected to a PME supply. This is supplied to a leb header by straight concentric 16mm cable and then to and RCD with outgoing circuits to the sign.
Now I have just seen that work by others have been carried out in the form of doubling up on the load side of the rcd for a socket and the loadside has been connected as pme (neutral and earth together ) and even at the electronic ballast, now Im pretty sure this is a NO as PME connection of this type is only allowed at source. (ie the head with the hfc fuse) Now am I right in understanding that the RCD will not have an imbalance to work from and therefore dangerous apart from the fact of bad practice.
head = 16a hrc
rcd = 10a
Please advise Kind Regards DEE
head = 16a hrc
rcd = 10a
