Discuss Points served - FCU's??. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
C
chrisgc
I know people have different methods but I was wondering would you count an FCU (feeding a single socket for an appliance) as a point?
In my head I dont count light switches, but I would count single socket = 1, double socket = 1, Ceiling rose = 1, Each downlight connection = 1.
Just not sure about FCU's?
I count anything that draws a load, sockets, lights etc... I don't class isolators as a point, an FCU isolating a single socket below kitchen worktop would be 1 point.
Oh and out of interest - do you guys count 2 gang socket as 2? I personally think its one - not sure if there is anything official wording from the scheme providers at all though.
Hi Chris, Your original thought was correct a double socket is counted as a single point. In a similar fashion a multi-lamp light fitting is counted as a single point.
I always think of "points" as fixed points where connections are made. i.e. 2G socket = 1, 1G socket =1, FCU = 1, light fitting = 1, etc, etc but as Amp David says there are a different views on the "count".
Another daft example of the regs where a simple explanation would clear up another anomoly.
My understanding is that it is a point of current using equipment, so sockets single or double count as one and light fittings count as one but I do not count switches.
FCU's supplying a socket as in a kitchen or utility room I would count as one.
I would only fill this in if i had done a rewire, or new build. Then if any additions are made by DIY charlie then it nulls and voids his guarantee.
Cheers..........Howard
As above. I also count a Cooker panel that has a single socket on it and with an outlet plate as 2. And a cooker panel that is just a 45 amp switch (no socket) but an outlet plate as one.
I use each point of current using equipment as one, (except twin socket which is 1)
Not sure it would affect any guarantees.
I went into a house a few weeks ago which had been rewired last year and the electrician had done a good job. However, the owner did inform me that the spark had missed a socket off the "number of points". The owner had taken an interest in how many sockets he had and it wasn't until the spark had left that he realised they'd missed one under a cupboard when counting them up.
There is no definitive answer to this, only personal preference. Personally I count every time a cable is terminated as a point. Excluding mcb. And if a fcu is feeding fixed equipment, I only count the fcu.
We'll all soon be taking photos of everything we install in order to cover our backsides ;)
I often do when labeling fcu's that may not be obvious to which appliance they isolate. You know the stickers will not remain there for any length of time
Reply to Points served - FCU's??. in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Grateful if someone could offer some advise, I'm struggling to find a definitive answer to this. I have a double socket, it was on the ring main...
Is this ok? 32amp breaker with a 6mm wire leading to fused cooker switch. This then leads with 6mm cable to hardwire point. Can i hardwire 2 x...
OLDBOY
O
I have been asked to look at this report as the customer has been given (in their words) 'A very high quote plus VAT'. It doesn't look well...
Hi All, As a householder I'm keen to add a double socket further along a wall to extend access in a different corner of the room. I'm connecting...
I have been asked/invited to "post more", lol, so let me make another post right away. I thought of sth worthy to post, of interest to many, I...
