Discuss Polyurethane insulation in the UK Electrical Forum area at ElectriciansForums.net
Hi
Needs some advice on running T and E in contact or along side Quinn Therm insulation which is basically the same as celotex I've been told it can melt the insulation of t and e cable when in contact I've got a big job coming up and don't want to risk it so might use fp 200 to be on the safe side if that is alright to use.
Any suggestions pls
Hi
Any suggestions pls
Just use LSF twe.
Most manufacturers of insulation board, including Quinn and Celotex, have switched from Polyurethane to the more stable Polyisocyanurate material. The older Polyurethane board often reacts PVC cable insulation plasticiser causing de-polymerisation of the board, resulting in the melting and fusing together of the cable and board. Polyisocyanurate is far more stable and resistant to de-polymerisation with most current PVC cable insulation formulae.
Hi
Any suggestions pls
Are we suggesting there can be some sort of chemical reaction between a PVC cable and polyurethane foam insulation, or of the need to derate the cable’s current carrying capacity because of the thermal insulation effect on the cable? Celotex state ' Celotex has no detrimental effect on the cable sheathing'.
Here's a link to their technical support.
Celotex Insulation | Technical
Celotex state that polyisocyanurate foam is more widely used in thermal insulation over polyurethane foam, because it is more difficult to ignite. No mention of polyurethane foam having a chemical reaction with pvc cables. Can you point me to the study on this?
So what's the answer to this can I use normal PVC t and e cable with Quinn therm polyurathane insulation and just protect it where it passes through the foam part.
Or do I need to use LSF cable instead of PVC and protect it as well.
Any help would be appreciated.
Reply to Polyurethane insulation in the UK Electrical Forum area at ElectriciansForums.net
I don't "do" solar, but I've been asked to comment on an aspect of a new domestic solar installation by others. There is no overload or fault...
Hi all, Was speaking to a family member recently, he told me his iron recently made a bang and flash as he plugged it in to the socket, and could...
Hi all. I'm after some practical advice please. Got a job to quote for, fitting a couple of gimbal downlights in a sloping ceiling in an attic...
