Discuss Ponds in the UK Electrical Forum area at ElectriciansForums.net
Cowanjack
Evening all,
I have recently installed a pond and run the pump back to a socket in the utility room (three pin plug).
However, I have just got a small shock from the water in the pond! I turned off the socket it’s plugged into but can still detect a voltage in the water. I then turned off the RCD for the downstairs sockets and still get a reading from the pond.
I live in a brand new house so any ideas before I call the builders in to investigate would be appreciated!!
Hi, Off the electric test screwdriver. Not sure what the reading was though First time though was unfortunately through a shock
Don't trust your neon screwdriver they are incredibly unreliable. If the pump has a 13a plug top on it you should have it PAT tested to start to see if there are any issues with it. Failing that the circuit it is plugged into should be investigated in case there is a broken earth etc. Is the circuit RCD protected?
Ok, sparky is coming tomorrow to check. Yep the circuit is RCD protected but the fact that I still got a reading even with the RCD turned off...
The neon screwdriver is next to useless and belongs in the bin so don't trust the 'reading's it gives. Best bet is to let spark test the circuit it is plugged into and check the pump over
Thinking about this again. If rcd is, doublepole it's almost certainly the case that the electrical issue and the pond pump are unrelated. Could there be other underground supplies in the area?
Reply to Ponds in the UK Electrical Forum area at ElectriciansForums.net
I have a fairly recently installed consumer unit with an RCD, between it and the garden there is another, much older (25yrs?) RCB (big Wylex...
Homeowner here, working on my fish pond power supply. (Fish pond came with the house and I'm wanting to update.) Currently 220v comes off of a 2...
Hi all. Sort of an interesting one. I had a call from a client to say she is getting a shock when using the shower. I told her not to use it and...
I'm looking at a vending hot drinks machine 2.9kW that has a thermostatically controlled hot water tank permanently attached to a water supply...
An RCD keeps tripping. Please see attached photo of the board (2 photos attached). I’ll call the breakers: MCB (1) marked ‘Upstairs lighting’...
