Discuss Porcelain Fuse BS??? in the Australia area at ElectriciansForums.net
L
leestaf
Hi Guys
Can anyone help? I have installed a supply fed from a new MEM3 DB 3P however this is fed via an old 3P switch fuse containing large porcelain rewirable fuses 60A.
Does anyone know the BS number for this fuse as i dont think its a 3036 as its not semi-enclosed.
Any help appreciated Thanks.​
Is the old switch fuse a MEM. BS3185 if it is a old ' Imperial ' blade type isolator up to 1970 I think.Today I think it's equivalent is BS 5419. If it is MEM you could phone them, they are helpfull.
Reply to Porcelain Fuse BS??? in the Australia area at ElectriciansForums.net
Setup: Consumer unit fed via sub main from a 60A fused isolator switch. This is connected to the service head MET via a 2m earth connection...
Hi Guys I have been following this forum over a number of years reading endless discussions and picking up things along the way. I am a JIB gold...
Hi I am trying to create a thermal cutout circuit to protect a large (10sqm) silicone heat pad table. The total heat pad load is around 30A...
Hi all, Apologies for long post. I have been asked to change two ceiling lights, an extractor fan and shaver socket in a bathroom, this is like...
Landlord has had an EICR done on the property as is required under the new PRS legislation, got a copy of the report and I'm not overly impressed...
