Discuss portable generator wring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
B
brightspark26
hi everyone i am a time served electrician and i have been asked to fit a consumer unit with 2 double sockets/ 1 internal light and 2 external lights
in a 12x6 box trailer
it will be supplied from a portable generator and supplied into the trailer via an apliance inlet
i have an issue that it may not be the same generator that supplies the trailer as its used for club events and it all depends what generator is there.I am intending fitting an insulated consumer unit with 30ma rcd main switch but im conserned about the earth issue
any ideas would be great
Sect 717 covers the basics but for the life of me I can't remember if we TT'd the whole lot and had bonding through the supply cable, years of alcohol abuse has ruined that for me...
Some info here...
Wiring Matters - 2011 issues - IET Electrical
Issue 39, summer 2011.
Also see attached PDF.
I got a generator with an earth spike and I connected the trailer up as per normal wiring and my tested showed no earth. So I bridged out n-e at the appliance inlet and then it showed and earth and allowed the red to trip. Is this the best way to do this ?
Hasn't this turned the installation into a TN system ?
I fitted a c form appliance inlet then hard wired from there.
The cable from the generator to the trailer was a flex in good condition.
I just want to make sure this is the correct method. I may bridged it out at the appliance inlet as the generator was hired in for 1 day. They are planning on buying a generator with a earth spike etc soon
Reply to portable generator wring in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Hi all, I've got a small catering business out of a converted horse trailer and purchased an inverter generator to power the trailer, mainly just...
6K
Hi Sorry to bring this one up again but have read numerous posts and answers and not got an answer specific to my situation. I have a Loncin...
I know it's not neat, but can I simply run a single extension cable from a small (3KVA) petrol, portable, inverter generator, positioned outside...
Hi All Had an enquiry about installing a generator fed UPS to a house. I have a minimal amount of experience with UPS but am certainly no expert...
Hi everyone. Hopefully someone can help with a little mystery i had today. The issue is fixed but I want to understand what was going on to help...
