Discuss Possible room to room networking solution? in the Computer and Networking Forum area at ElectriciansForums.net
Hi, electrician here with basic networking knowledge.
Please see attached picture.
Im trying to over come a problem and just wondering if my possible solution will work or not.
A router has been installed in a room of a house via a junction box in a hallway where the telephone cable comes in and from here a 4 pair cat 5 cable goes to every room.
Is it possible to use the spare cores of cable 1 to come out of the Ethernet port of the router, come back down to the junction box and connect to cable 2.
Will I then be able to plug this into a switch and have wired Ethernet in room 2.
If it is possible, are there specific pairs i need to use?
thanks in advance for any help
Did some research on what pins do what in an ethernet cable, as I know some are unused.
Source: https://www.iplocation.net/rj45-wiring
and have come up with this monster, however there is no guarantee this would work, it's just what I think would work and would require testing.
Hope this helps
Wow, thanks man. Really appreciate it. I knew there was something about unbalancing the pairs that might make it not work. I didnt realise ethernet requires 2 pairs; why is that? Also can I use any sets of pairs? as Im not sure what has been used in cable 1 already
Thanks again.
Honestly don't know if you can use any sets of pairs. They are twisted to reduce interference and that would be the only issue I could think of. So long as you use pairs, I don't see an issue, just make sure you use a network tester because if any of the pairs are not kept as pairs, you can get cross talk depending on the length of the cable depends on the severity.
The reason for 2 pairs is for the transmit and receive wires.
Tx+
Tx-
Rx+
Rx-
Reply to Possible room to room networking solution? in the Computer and Networking Forum area at ElectriciansForums.net
Hi all I’m after a bit of advice regarding wifi/secondary router. Data is not a strong point of mine so any advice would be very much...
Hello everyone... There are a total of 4 cables entering the junction box at the top of the staircase. Two 12/2 cables are coming in through the...
Hi I've been planning to fit an outdoor junction box at the front of my house to hide a large brickwork hole and properly house the wiring...
Hello I'm Ronald Alliy, I have current came up with what I believe is a Infinite Electricity source. Attached is my proof. I'm a noob at blender...
