Discuss Potential hazard or not? in the UK Electrical Forum area at ElectriciansForums.net
We've had a safety memo sent out to us all today regarding a new type of compressor we are using.
In a nutshell, its single phase, ran off a plug top to a rotary isolator on the unit. The L/N/E all go through the isolator, so.. when you switch off the isolator, you're switching the L,N AND E.
The H&S have identified a potential hazard where 'this wiring could lead to a potential electric shock, if the unit develops a fault in the wiring between the main plug socket and the unit mains isolator, if the mains isolator switch is OFF'.
Forgive my stupidity (or maybe not), but I fail to see how this could cause an electric shock if the mains isolator is OFF. The only issue I can see is, if the rotary isolators L2 contact (where the Earth is connected into) for whatever reason failed/burnt out etc, and L1 (Live) and L3 (Neutral) were fine, you could have a situation where you have no earth to the compressor at all. Which of course is an issue.
I may be reading this wrong, or they may have made an error.. Suggestions open.....
Consider the isolator is faulty and in the off position still maintains a L feed only due to mechanical failure, you have effectively put a feed to a unit and disconnected the earth, also in such set up, the N would float at 230v which heightens the risk of shock to a user, another scenario would be water ingress to a isolator in the off position could track to the load without an earth... there are many examples and scenarios as to why this is dangerous and why regulations do not allow it.
Also, the capacitor/s within the compressor may remain energised after the CPC is isolated, the appliance is Class 1 therefore depends on the CPC else in a fault condition a shock may result from touching the casing.
Reply to Potential hazard or not? in the UK Electrical Forum area at ElectriciansForums.net
Hi all. Sort of an interesting one. I had a call from a client to say she is getting a shock when using the shower. I told her not to use it and...
Hi, after a bit of advice. Have tried a lot of plumbing and electrical shops but no one seems able to help. I have an Isolator/PSU 230v/12v. It is...
Hi, I have received conflicting advice about Main Isolator Switches and would appreciate forum member's help to plan a way ahead. Looking to the...
Deleted member 155212
Hello all, Looking for help here as I've come across a strange call-out today. Bare with me here: Got a call from a customer saying they had...
Hi, I'm interested in a house built around the 1980's in Northern Ireland. I took a few photos of the consumer unit etc. which is situated in the...
