Discuss Potential Transformer Testing in the Canada area at ElectriciansForums.net
A
asif
Hi,
Please advise me that how can i test 6.6kV PT because it is much older and i have reconeect at our system after checking it.
Asif
Hi,
Asif
I would "megger" it then connect " 240 to it via a breaker of some kind and measure the secondry with a volt meter ,if the breaker holds and you get a steady output voltage, just connect it it the circuit and give it a try
best of luck:)
Reply to Potential Transformer Testing in the Canada area at ElectriciansForums.net
Hi all. We have a 120v 20 amp circuit to an accessory dwelling with a run of about 75' of direct bury #12. The breaker keeps tripping even when...
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
Hi everyone, I need help installing a Lorex smart doorbell. I have tried to install a doorbell transformer several times to no avail. The first...
Hope you're all well . I've had ring door bell 2nd generation hardwired for 1.5 yrs... it was connected to transformer which is connected to the...
Hi All, I've failed... I've come up stumps. Can anyone advise me where I can find a replacement transformer for the attached transformer...
