Discuss Power outage to kitchen area in the UK Electrical Forum area at ElectriciansForums.net
Rajen
Hi,
The power supply to part of the kitchen has gone. This includes fridge, cooker, fan extractor, dishwasher and some power sockets to the kitchen worktop. Rest of power sockets in the kitchen have power and rest of the house is ok.
The switch for "Cooker" in the RCD was in the up position. I've moved it into the down position and back up but this hasn't fixed it. Also, tried to replace all fuses in the switches for box with diswasher, fridge, ... but no luck
Does RCD switch for the Cooker need changing or is this a job for an electrician ? Is there else I can do to find the cause.
Photo of RCD, fuse switch box and red switch near to cook.
afraid a call to a local spark is your way forward. post your location. one of us may be close.
Hi Rajen
From what I can ascertain from your description of the problem, it looks like one of RCDs has tripped taking out the supplies to the MCBs served by that particular RCD.
This could be a wiring fault. or more than likely a faulty appliance, unplug all the appliances on the circuits, affected, and reset the RCD, if it stays on then the problem is in one of the appliances, plug the appliances back in one at a time until the RCD trips out, if not then unfortunately it looks like you have a wiring fault, and will need the help of an Electrician to locate and repair the fault, as Teletrix has mentioned.
Hi Rajen
Thanks - silly questions... how do I reset the RCD? I noticed there is a middle button in the off position. Is meant to be in that position ?
Reset the RCD as you would an MCB by switching it back on. No it's meant to be in the ON position.
Where are you situated? PM me with your Post code if it's not to far I could help for the price of the fuel used. my experience you can have for free.
Nice one Pete, you've fixed it without even getting the tools out!
Not really rocket science for the electrically knowledgeable, un fathomable but for the uninitiated the simplest things can be unfathomable, not the OPs fault, just simple for a Spark, but thanks for your comment anyway, sometimes a quick think can avoid scattering screwdrivers about, but I do love my screwdrivers, don't like getting them out, they are fine where they are safe and sound in my tool bag, only get em out every now and then, my screwdrivers that is.
once a tool tart, always a tool tart. instead of crossed swords on your coffint there will be crossed Weras.smiley.
i ave both, wiha and wera. ner ner.
best ones I have I borrowed from work about 5 years ago ITL is the make insulated tools limited. expensive, well no to me they were FOC forgot to hand em back, reckon they will miss them???
Reply to Power outage to kitchen area in the UK Electrical Forum area at ElectriciansForums.net
Hi all. So I'm designing my new kitchen and trying to plan where things will go. I currently have a 6 switch panel for the appliances (hob...
Hello everyone, I'd like to seek your input on a matter. I'm in the process of designing the electrical connections for the following kitchen...
Hi there, wondering if anyone can give me some advice please. In my kitchen I have a cooker switch with a plug socket which I believe is on a...
Hello, So I noticed my fridge had lost power, disconnected it and tried a hoover in the same socket and this also wouldn't work. I tried the...
