Discuss Power Rating in the UK Electrical Forum area at ElectriciansForums.net
Jadele
Got a pic off a customer of a machine data plate. Bit odd with the two ratings and the other with the + signs in. Can anyone help? Is it startup and running current or something else?
Am I also right in thinking the 1 st pic machine is going to pull about 47 Amp per phase?
Thanks in advance
The rating of the second machine appears to be indicating the load as two motors of 10hp and 1.5hp separately.
On both machines the rated current (Nennstrom) is given and you should work from that, not the kW rating, as it will take into account the power factor etc. 67A for the first machine and 18A for the second.
Reply to Power Rating in the UK Electrical Forum area at ElectriciansForums.net
I'm sorry if this isn't in the right place but this is my first time using this forum. I'm also sorry if i make some mistakes but I'm new to this...
I have a question which is confusing me and I cannot find a definitive answer and I hope someone can help. So I have a PC and Monitor and I have...
Hi, The `power went out throughout the house this afternoon but only to the sockets, the lighting circuits are all fine. I went to the consumer...
I'm in the middle of preparing a quote for installing 12 x 3Kw and 4 x 2Kw halogen heaters in a church. The system design was provided by a...
Absolutely losing my brain here guys What I would like to be able to do is power our 3 phase motor on a single phase supply. Thought I had it...
