Discuss Power to my shed in the UK Electrical Forum area at ElectriciansForums.net
Andre2057
Hi guys
Looking to upgrade the power to my shed, currently use a extension cable.
I have 2 spare spaces in my consumer unit in house so hopefully be able to add to it for the shed, which would have a 4way or 6way consumer unit in it.
Would be about 25-30m run of cable , would 6mm t+e be enough or would I need to go to 10mm?
Cheers Andy
Hi guys
Cheers Andy
Hia mate all depends on the job all sparkys differentiate job to job either 6mm or 10mm would be sufficient depending on load at shed quite a fair run to shed though so I would imagine 10mm being the preferred choice
Hi guys
Cheers Andy
Depends on the eventual load required at the Shed, have you done any Volt drop calculations? how do you intend to install the new cable? what type of cable do you intend using? will the spare ways in the House CU provide RCD protection for the Shed? Sorry didn't notice you mentioned TandE not an ideal solution.
1mm might just do a couple of LEDs and a phone charger. :eek::eek::eek:
I was being a little sarcastic, although technically true. What I wanted to say is that if you are designing it then you'll know what size cable as you'll be an electrician :D
Hi yes intend to put a new RCD in consumer unit in house if t+e not best what cable would be?
ifyou're having a RCD in the shed, you don't want to feed from a RCD way in the house if using SWA cable. best advice is to get a local sparks to quote and design for you. appears you're in Scotland, regs. there different to England.
As a general rule of thumb I use either 2.5 or 4mm swa for near all shed hock ups which require a socket and a light.
If it’s more a work shop then will do a proper evaluation of what equipment is actually going in the work shop
Ok cheers was looking going to look for a spark just going to run the cable myself
If you are employing an electrician might as well get them to price the whole job and see what it comes out at...
I wouldn't attempt to run the cable yourself until you have spoken the Electrician and discussed the type of cable best for the job, from your previous post I really don't like or understand the method of installation you have described, the electrician will advise what you can do in the cable installation, digging trenches maybe, but not having eyes on the job it's very difficult to assess, good luck.
As above, have a talk with the electrician who will be doing the job before you attempting to do any work on it. They can dive you the type of cable, cable size and what is the best route for the cable.
Save time and money. You install cable, but get your spark to do cable calcs to ascertain size.
You could waste a lot of time and money if you install the wrong size.
I did this recently. Customer paid me to do the calcs£50. He bought and fitted the 10 mm 50M SWA I the came and did the easy bit.
Reply to Power to my shed in the UK Electrical Forum area at ElectriciansForums.net
Hi guys, I have supplied my Shed with a 6mm SWA cable into a nice consumer unit. In there I have a 6Amp MCB for the lights and a 16 A supplying a...
L
So my old man is planning on setting up a fish shed which will hold 2-3 fish tanks. The power drawn from the equipment which will be running in...
I have had my kitchen rewired and plastered. I have had a 6mm t+e on a dedicated 32a circuit for a 60cm electric cooker. In hindsight, had i known...
Hi All I'm new here. I have just finished my NVQ and waiting to do my AM2. I have a question on selectivity as it has always slightly confused me...
Been asked to move, remove and add some sockets the kitchen and I’ll need to add a circuit for an electric hob. Looked at the board and it’s one...
