Discuss Power to Shed in the UK Electrical Forum area at ElectriciansForums.net
Hi All I’m new to the forum thing so go easy on me ;-)
if I am planning on putting a garage unit into my shed which will have a 32amp for power and 6amp for lighting is that OK to be fed from a 40amp breaker from the main board in the house ?
I didn’t know because of discrimination if I could just put the garage unit on an MCB ( which is in an RCB with one half of the circuits from house ) or if the shed circuit ( distribution circuit) would need to be on a Separate RCB/RCBO.
I know if there is a fault in the shed then the shed RCD would trip but if there was a fault between the shed and the main CU it would trip the house RCD.
If the Shed has to be on an Separate RCD then that would mean using an RCBO and since it just an RCD board I would need to replace the house board to be an RCBO board.
hope that all makes sense. Hope someone can shed some light on this.
2 RCDs on the same leg is not a good idea, this is a private job other than your full time employment I have assumed???
A fault in the shed will trip the RCD in the house if it is connected to it, the RCD in the shed will also probably trip.
Could you get a SWA to the shed? Are you able to calculate the appropriate size?
Is this job op, are you work for a company or your self ?
im just starting out this job will just be for my dad
[automerge]1580765223[/automerge]
It’s for my dad and he already has 16mm2 , this is overkill but might as well over egg it than under egg it.
[automerge]1580765265[/automerge]
Don't put RCDs in series. What size/type of cable are you using?
SWA 16mm2
if there is room on the fuseboard, you could add an MCB between the main switch and the RCD to feed the shed. 32A would be fine.
then into the shed fuseboard which would have it’s own RCD feeding the sockets and lights.
should a fault occurs the shed, it will trip the shed rcd, not the main house one and visa versa...
Great thanks this is helpful and think it is the way I will do it. We have enough SWA to go from the utility to the shed but not the main board so would the follow be OK.
1. A 16mm2 T +E from a MCB at the main board( not RCD protected ) the 16mm2 T+ E will then go through the house to the Utility.
2. 16mm2 T+E will then be joined inside the house utility to a SWA 16mm2 up to the shed. It will be joined via A separate main switch with will be on the wall inside.
3. Once joined the SWA will lead to the shed board which will be RCD protected.
I no ideally you would have an SWA from the shed to the main board but we already have the cable so will joining it via a separate main switch at the back of the house utility be acceptable ?
But does it meet the requirements for not having RCD protection?
Yes - Apart from the fact it would be connected to the SWA which does run outside ( which when a cable is used in the garden it would be require an RCD) but then again the termination won’t be outside as it would terminate in a shed.
otherwise I guess it would be better to run the cable from RCD protected inside and have no RCD in the Shed ?
I'm not sure you've fully grasped the requirements for RCD protection.
I was meaning the 'less than 50mm depth ' rule.
95% of the cable runs through the floor not in the walls so the 5% that does run down the wall to the where it joins the swa via a separate main switch , I will make sure either it is 50mm back in the wall or it has mechanical protection. Apart from that I think it’s fine yeah ?
Why on earth do you want to join it using a switch?
And why extend it with T&E?
[automerge]1580849657[/automerge]
What is the wall made of? If it's a solid wall how are you going to cut a deep enough chase without damaging the structural integrity of the wall?
Reply to Power to Shed in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Curious one and hopefully some one of you could give me some advice. A customer has had a steeltech shed installed at their premises. A...
Hi, I'm looking to get the lionshare of a small shed wired before a friendly electrician does the needful. I'm a confident DIYer, but I would...
Hi guys, I have supplied my Shed with a 6mm SWA cable into a nice consumer unit. In there I have a 6Amp MCB for the lights and a 16 A supplying a...
Hi all Now being upfront I am not a sparks. I am about to have some work done by a friend (certified) and as he is doing me a favour I want to as...
Hello all, Looking for help here as I've come across a strange call-out today. Bare with me here: Got a call from a customer saying they had...
