Discuss Power track in offices in the UK Electrical Forum area at ElectriciansForums.net
cliffed
Supporter
Giving a hand to some sparks on a real nice job..but..
Anyone fitted the power track system,bus bar & the plug off’s to sockets.
It states they are 3 metre lengths,if over then these leads need to be fused.
It’s a 63 amp system,with a 40 amp Rcd,also plug in 1.5mm flex,can’t get my head around this.
It’s all factory made,& all the bits have been sent,but why a 40 amp Rcd protecting the cable.
So it’s 63 amps,leads are 4.0mm straight from plug off,then 1.5mm of the Rcd.
I think the power track we installed had a 32A protective device feeding the track and the floor boxes had 4mm from the box to the plugin installed inmetallic flexible conduit.
Thanks all,yes the Rcd is for the sockets,I think the Rcd will need to be changed from 40 to maybe 32 or 16 amp.
Especially with the 1.5mm supplying sockets.
As above, what's the reason for down rating the current of the RCD?
This is the sort of equipment,this plugs straight into the 63 amp bus bar system.
look at my post regarding earth leakage, they might want to change there minds!!
So the 4 way is restricted to 12.6A effectively, I can't see 1.5mm having an overloading issue.
Ok,I personally haven’t seen something like this,this can be directly plugged into the Busbar,obviously the 3m length determinates the overload protection required.
@the moment this lead is actually on the Rcd module side,which is a 40amp rcbo,still not getting it though.
The Chiefs say it’s ok,it’s a factory manufactured plug & play.
Reply to Power track in offices in the UK Electrical Forum area at ElectriciansForums.net
We have a customer in a large office block with all power in the building fed from an Electrak plug in busbar system. Lots of desks, lots of...
Hello All, new to the forum. Would be grateful for advice on whether the following proposal is an acceptable solution or open to any suggestions...
5K
Hey guys and gals. We bought a small office trailer that is wired up. It's never seen mains power and uses a generator disconnect (220). I read...
Hello all I have recently installed a sub main in 4mm 3-core SWA, approx length 45 metres, to feed a small garden office. Final circuits in the...
