- Reaction score
- 4
My power keeps going off and comes back on after a couple of seconds. No trips on the circuit board. Happens once a day for the last week. Any ideas?
Discuss Power trips in the UK Electrical Forum area at ElectriciansForums.net
Haven’t checked with neighbours just yet. Basically everything goes off, then comes straight back on. No trips. I changed a light fitting a couple of weeks back but that’s been off when this has happened. I did remove it this morning and check all the connections and all looks good.Could be your DNO is having problems in your area. Have you checked with neighbours and/or the DNO to see if there is any known problems with the supply in your area? What happens that tell you the power has gone off? May sound like a silly question but it could provide clues as to what is going on if you describe it.
I’m not in a Rural area. It’s a fairly new estate, 6 years old, in Elgin, morayshire. Not sure what OHL is and what we’re fed from.As per Vortigen, do you stay in a rural area fed from OHL? DNOs use auto-reclosers and auto-sectionalisers which can cause brief interruptions to supply. As far as the DNO and regulator are concerned, you haven't had a supply interruption unless it is more than one second.
Reply to Power trips in the UK Electrical Forum area at ElectriciansForums.net
