Discuss Powered Wall Chasers in the Electrical Tools and Products area at ElectriciansForums.net
I have used them a few times and think they are great, if you are worried about dust just connect your hoover to them, fast neat and clean, Also nice clean lines for plastering
Mark
Try a 'Sparky' wall chaser from Screwfix. I have two 125mm ones on the go. They are not too dear either BUT they are German so made very well. The wall chaser is a must BUT ONLY if you have a good extractor. Look at Bosch Gas25 Or Gas50, they have a vibrating filter which stops clogging. Numatics 'Henry' also works but get re-usable bags not paper ones. The 'Henry' is considerably cheaper also.
If you want the best though, its the Hilti DCSE-20. Big Big Bucks new though.
Hi,
I'll use a chaser on a new build site,e.g. extension etc., because of the dust otherwise it's Bosch SDS and chisel. Keeps the customer a lot happier I've found.
I ve got a Hilti chaser complete with a hoover . If you are going to invest in one get the best you can afford because the cheap ones will only brake. My hilti is worth its wait in gold and with the help of a hammer chisel we can chop a 3 bed house out in 1 hour. Take 30 min the clear up though. If you position the chaser correctly there is'nt any dust just make sure the hoover is empty
Ive used cheap chasers before and everyone broke.
I dislike SF - never buy anything from em personally. Better deals at the wholesalers IMO
Talks sense, Proper extraction, henry hoover is spot on, saves destroying plaster that is already blown, if you like plastering carry on smacking the life out of walls, chasing machine is simple , cost effective and clean
only had a quick glance looks ok tho you never know what the plasters hiding so you get more feel with a hammer and bolster but im 2 lazy so i like a sds with a chisel bit rememeber once when i went through a gass pipe could of ended in dissaster :O lol
I use the Sparky one, £100. Connected to a henry hoover, works a treat no dust at all. I cut a chase in my nephews room an you can't tell I have been there except for the making good
Reply to Powered Wall Chasers in the Electrical Tools and Products area at ElectriciansForums.net
Hi, I have lifetime experience (50+ years) in United States with basic knowledge of split phase 120/240 volts replacing wall switches and...
Looking at purchasing a wall chaser and hoover set and wondered what brands were being used with members and if you were happy with the kit...
7K
Hi there, I’m a new member to the forum and felt like I could do with some additional insight into a fault I came across on a call-out at the...
Howdy DIY soldiers, first post here. My question comes down to whether it would be particularly unsafe for me to temporarily wire nut and tape a...
