Discuss Powering floodlights in the Lighting Forum area at ElectriciansForums.net
iolar223
Hi, I’m looking to install two floodlights to light a farm yard, that doesn’t have a supply of electricity. So I was wondering if they could be powered with a small generator or a large power pack.
Welcome to the forum mate.
A small gen for a couple of light is a bit expensive, unless they already have one.
What size lights are you looking at?
How long do they want the light on for?
Are they PIR or permanently on during the night?
Do they want to control the light with a switch?
I haven't used them myself but I'm aware there are some very good solar+battery self charging options available now.
Some years ago I wired up a small isolated yard to trigger a generator start up from 12v PIR's, to bring on several halogen floods.
Worked very well.
Reply to Powering floodlights in the Lighting Forum area at ElectriciansForums.net
I'm from Sri Lanka. We have installed LED Floodlights from two different Italian Brands (I can mention the names if wanted) on two different...
Hi all, I have a single switch in my garage to turn on a couple of lights in there. Yesterday I fitted a floodlight outside, drilled through...
Hi, I’m new to the forum. Thanks for letting me join. Asking for some diy advicd… I’m trying to add a couple more security lights to the existing...
Electrical2Go - Home Security: Using Floodlights, CCTV, and Door Entry Systems In an era where technology is advancing rapidly, home security has...
Hi all, I'm looking for a couple of PIR floodlights to replace old halogen ones, probably around the 50W mark would provide sufficient lighting...
