Discuss Pre-work survey sheet in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
spraymate1
Hi guys, I'm looking for a pre-work survey sheet, template, so I can record test results such as Ze, Bonding, PFC etc for when doing cu changes etc, many thanks.
Here is a Pre-work Survey that I thought might be useful, I typed it up but not telling where I got it although some would know.No good in a bloody book , need to have the form to fill out.Included a Results pdf from above post.:hurray: I can modify it if need be !
  • Test quick check results Schedule.pdf
  • Pre-work Survey.PDF
Here's another one, much more detail and a comments column for recording any values.
Because of the detail on this, you can use it as part of your terms and conditions, a full list of every detail agreed, right down to 'making good' !
  • Contract Assessment.pdf
Reply to Pre-work survey sheet in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi Guys, hopefully someone will know the answer. Testing an install on a (domestic) PME system I have a garage consumer unit supplied from one of...
Morning guys, Just been to look at a CU change and there was a bit of an oddity with the PME connection in the old black cut out. Looking at the...
Evening everyone, I was taught when carrying out Zs testing to test both L-PE and L-N and record the highest result of the two tests for my Zs...
Morning guys! Went to look at a consumer unit change today with a PME supply. Now, right next to this was an old BS3036 60A fused mem cutout...
Hi all, Is there companies or people out there that can help source sub contract work as im not sure where to start. I know you get recruitment...
